Power trim pump problem. >
Old 05-03-2009 | 02:43 PM
AppSysCons's Avatar
Default Power trim pump problem.
2004 Merc 350mag/mpi Bravo1, 154 hours. Drive goes up/out fast and smooth, pump sounds OK. Will not go down/in, unless under load, and pump sounds weird. When I am running, it goes down fine. Plenty of fluid in reservoir.
I am guessing that the down/in pressure relief “green” valve is the problem. I do not have access to a hydraulic test gauge.
Does it sound like I am on the right track?
Is this something better left to a Merc Tech?
AppSysCons is offline
Old 05-03-2009 | 05:35 PM
Audiofn's Avatar
Charter Member #232
Could be a messed up seal in the rams as well. I would disconnect them at the back of the drive and see if they move together. I had the same issue and it was a bad ram.
Put your best foot forward!
Audiofn is offline
Old 05-03-2009 | 08:48 PM
EWPE's Avatar
So have I, on two different boats.
EWPE is offline
Old 05-03-2009 | 08:53 PM
SEAL IN RAM ( O- RING ) !!!!!!!!!
Its bypassing !!
DareDevil is offline
