HP and max RPM? >
HP and max RPM?
HP and max RPM?
Old 05-04-2009 | 02:11 PM
Default HP and max RPM?
Hey, i just purchased a 95 Crownline 225 CCR with the 454 Mag and was wondering if anybody knows the numbers for the HP and max RPM? Thanx
95CROWN is offline
Old 05-04-2009 | 02:56 PM
DORaymond's Avatar
I believe the 454 Mag was 365hp at 5000 rpm.
DORaymond is offline
Old 05-04-2009 | 03:00 PM
I think it was @ 5200 and i always ran them 5400 never had a problem !!!
DareDevil is offline
Old 05-04-2009 | 05:50 PM
awsome. thanx
95CROWN is offline
Old 05-04-2009 | 06:56 PM
Carb 365 injected 385 both run at 5200.
RBeyer is offline
Old 05-05-2009 | 01:37 AM
454 mag carbed is 365hp. WOT range is 4600-5000rpms per merc specs. You can run them to 5200rpms, but the torque falls off. If it has TB IV ignition, there is no rev limiter.
454mag EFI is 385hp. WOT range is 4600-5000rpms per merc specs. The TB V ignition rev limiter should kick in around 5150rpms.
Griff is offline
