RPM Difference >
RPM Difference
RPM Difference
Old 05-11-2009 | 01:36 PM
Strip Poker 388's Avatar
Rob
Originally Posted by Drag 'N' Ass
Not going to change the ratio, trying to figure out whats going on. Suppose to have 1.50 drives boat, but only turning less than 4000 rpms. This boat should be turning 5000-5200 rpms with a 30" prop. Dealer changed lower units on Bravo drives so the serial number will not match up with ratio.
Maybe the foot has differamt gears than your old one?
do what daredevil says
Strip Poker 388 is offline
Old 05-11-2009 | 03:01 PM
ROADHOG's Avatar
Stevesxm, Your right the boat is a 2006 42 Ex with 525's, My last boat was a 2005 42 Ex with 525's. The reason I'm asking this question is because the 2005 would run 30' props to 5000-5200 rpms. The 2006 will not go past 4000 rpms. I know the dealer switched the lower ends on the Bravo's with another boat and I'm hoping they did not put 1.36 on by mistake.
The 30" props that are on the boat are the ones they issued with the boat at time of purchase. I'm just thinking that the drive ratio's are incorrect,because my 2005 Ex would turn 30" props 5000 rpms all day long.
ROADHOG is offline
Old 05-11-2009 | 04:40 PM
sounds to me like your logic is impeccable
stevesxm is offline
Old 05-11-2009 | 04:49 PM
ROADHOG's Avatar
If you knew me, you would be giving me TOOOO MUCH CREDIT!!!!
ROADHOG is offline
Old 05-12-2009 | 12:46 AM
1000-1200 rpms ?????? They might even be 1.25's.
Griff is offline
Old 05-12-2009 | 09:05 AM
PatriYacht's Avatar
Did you buy ANOTHER boat?
PatriYacht is offline
Old 05-12-2009 | 11:11 AM
ROADHOG's Avatar
YES!
I hope I did not make a mistake.
ROADHOG is offline
Old 05-12-2009 | 11:50 AM
PatriYacht's Avatar
Mistakes can always be fixed. Just takes $$$$ Would you like to borrow a pair of 26 pitch Bravo's to see how they run? I won't be in the water for another week or two.
Old 05-12-2009 | 12:24 PM
forgive my ignorance as i am not a prop expert or even knowledgeable but wouldn't just putting on shorter props to bring up the revs be the same as just putting on shorter tires on a car ? i.e ... yes the revs would come back but the top speed wouldn't be there ? for example... for the sake of discussion if the motor spins 4000 w/ 1.36 gears he is getting 2950 prop revs w/ a 30.
now a 28 is roughly 6 % less prop which would require only 6 % more revs for a "break even" or roughly 4250 ... lets say it actually does that... but what he really needs is 25 % more revs so that would imply an impossibly small prop... and no top speed at all....
now.. i understand that this whole thing is not precisely linear like it is w/ tires but it is substanatially so.... and you have the added unassailable fact that this combination worked flawlessly in what are essentially identical circumstances on the first boat...
i think something else is fundementally wrong. this seems like way too much " problem" for an incremental prop change...
i don't have any meaningful suggestion or solution but it just doesn't add up for me somehow.
stevesxm is offline
Old 05-12-2009 | 01:04 PM
ROADHOG's Avatar
Your right, not trying to fix the problem with the props. The drive train is the first place to start. The boat is in the shop as we speak and one way or another they will find out is going on.
Maybe it's something in the engine managment system that's not letting the engines come up to full RPM'S.
ROADHOG is offline
