Bravo won't turn up >
Bravo won't turn up
Bravo won't turn up
Old 03-25-2002 | 07:59 PM
blue thunder's Avatar
See Formula 31.... you guys are teaching me too much... now I'm getting danggggerous!!
BT
blue thunder is offline
Old 03-25-2002 | 11:23 PM
Blackhawkdn
One other suggestion is to check the "x" dimension if the starboard drive is deeper than the port drive this will cause less rpm. It is not uncommon for someone at the factory to make this mistake. THe Bravo drive turning right or left hand uses the same power.
Old 03-26-2002 | 07:24 AM
Mbam's Avatar
Offshoreonly Advertiser
Yep, checking the X dimension is a good one.
Mbam is offline
Old 03-26-2002 | 11:46 AM
Reckless32's Avatar
Rough Seas Lie Ahead
X-drive....That is a good one....
Reckless32 is offline
Old 03-27-2002 | 01:48 AM
Reckless32's Avatar
BTTT...
customtouch
Baja
71
11-18-2006 08:14 AM
Bigracks
Baja
22
10-01-2006 10:01 PM
SinkorSwim
04-22-2003 11:29 AM
Advantage_Rob
01-24-2002 02:22 PM
