Cracked exhaust manifold?
Is there a way to determine if an exhaust manifold is cracked? Or do you simply eliminate all other causes (cracked head, bad head gasket, cracked block) and assume?
Wondering if a local marine shop has a way to determine if I bring it in? |
Originally Posted by customfab
(Post 2865695)
No Pressure tester: take it off and fill water jacket with CRC if its cracked you'll see the leak. You can buy CRC in a gallon jug. Drain it back in jug and save it for next time.
Originally Posted by Clustergear
(Post 2866059)
| All times are GMT -5. The time now is 04:46 AM. |
