MSD Distributor Hook Up >
Old 05-16-2009 | 07:42 PM
Default MSD Distributor Hook Up
Need Help.
I have the MSD Pro Billet Distributor and i was wondering how do i connect to the ignition box..
it is the # 85551 and my problem is that it has the Black with orange strip, black with purple strip, solid purple, and solid grep wires on a connector. but on my MSD 6m-2L ign box does not have the connector to match..
do i just snip the wires and use different connetors..
thanks..
hope i'm making a little sense with this..
q
qaberdeen is offline
Old 05-16-2009 | 07:48 PM
Here's a pic of the wires
Old 05-17-2009 | 05:45 AM
Does your MSD box not have the standard twin plug outlet? Should have a Green and a Violet pair coming out the oposite side of the box to the main wires.
Violet is Mag (+) and Green is Mag (-). They match up to the corresponding striped wires, Violet to purple.
If you don't have the correct plug end, just snip the dist one off and use a two pin weather proof connector or deustch connector.
File Type: pdf
Ghostrider is offline
Old 05-17-2009 | 11:07 AM
Thanks Ghost Rider
