ignition timing >
ignition timing
ignition timing
Old 05-21-2009 | 06:51 AM
Default ignition timing
500hp carb, initial timing 10 and total timing 3000 rpm and set at 34 is this all correct.
rssteiny is offline
Old 05-21-2009 | 08:54 AM
hoozeyurdaddy's Avatar
that should be fine.
hoozeyurdaddy is offline
Old 05-21-2009 | 08:56 AM
I run 12 and 36. But 10 and 34 would be a save starting point.
jeffswav is offline
Old 05-21-2009 | 12:29 PM
racinfever's Avatar
Don,t forget to ground the timing wire.
racinfever is offline
Old 05-21-2009 | 06:37 PM
what wire i never did that before when i timed these engines.
rssteiny is offline
Old 05-21-2009 | 10:05 PM
racinfever's Avatar
HP 500 carb You must ground the timing wire to put the spark knock module in stabil mode. should be a purple wire with yellow tracer, rubber plug in the end. rear of intake manifold. See mercury manual under M B T adjust tune, Means Best Timing.
Old 05-22-2009 | 12:17 PM
If tis a TB V you need to put it in timing mode as stated. If its TB IV, you don't need to do anything.
Griff is offline
