420's to 600 >
420's to 600
420's to 600
Old 05-21-2009 | 09:08 PM
barron's Avatar
Default 420's to 600
Whats it going to cost to up grade merc 420's to 600hp? And can it be done w/o blowers?
barron is offline
Old 05-21-2009 | 09:34 PM
1.stroke it to 496
2. good heads
3. intake
4. carb
5. have RMbuilder do a cam
Not cheap but very doable.
Darrell.
DMOORE is offline
Old 05-22-2009 | 12:19 PM
It would probably cost less to add blowers and would be just as reliable.
Griff is offline
Old 05-22-2009 | 02:09 PM
Rookie's Avatar
I turned my Merc 425's into 590HP.
1. Fully ported and wedged steel heads flow 380in 270ex cfm(done by JimV)
2. 9.6:1 SRP forged pistons 0.070" over
3. Wieand Stealth dual plane intake with the floors welded up to match the heads.
4. Solid roller cam 252 264 @.050 0.630" in 0.630" ex on a 108
5. Barry Grant 750's (carbs are a little on the small side, should use 850's for more power)
6. 6000-6500rpm was 585-590HP
Edit:
7. Dry exhaust to the tips
Rookie is offline
Old 05-22-2009 | 10:55 PM
KAAMA's Avatar
Don't know how reliable the dyno was, but I had a pair of 468cid Naturally Aspirated engines make 620hp with Merlin OVAL port heads with 2.30" intake valves and well done bowl/pocket port work done to them, Dart single plane intake manifold, SOLID roller cam, tubular dyno headers, 9.5 comp ratio........they supposedly made 620hp @5700rpm. This was back in 1994. Have fun.
KAAMA is offline
