sea water pump impeller??? >
Old 05-25-2009 | 03:37 PM
Default sea water pump impeller???
Hello All,
The first run out today after a brand new take off sea water pump and the impeller lost 6 vanes the pump and impeller were brand new . What would cause this to happen , would two new tube coolers and a fresh water system cause this to happen. I don't believe I sucked something up but can't be so sure. The exhaust is brand new aluminum , how much heat can these take up you can damage them . I did not take a long just a easy cruise , has anyone ever torned one of these new mercruiser bravo sea water pump impeller up . Any advice would be greatful. Thanks Alec
alecsammy is offline
Old 05-25-2009 | 03:52 PM
Did you swap the inlet and outlet hoses by mistake on the sea water pump ?
Did the cooling work OK initially and then it suddenly happened, or did not work from the beginning ?
For that to happen you would think that somehow the sea water pump did not get sea water and hence it is ruined.
Phazar454Mag is offline
Old 05-25-2009 | 05:14 PM
I don't think it matters if the hoses are swapped, but they were installed the way they came off . The pump worked fine on the hose and when I first put it in the water.
Old 05-25-2009 | 05:17 PM
U DON"T THINK IT MATTERS IF THE HOSES ARE SWAPPED ?????????
DOOOHHHHH,,,, SO U RUN WITH AIR INSTEAD OF WATER ???
DareDevil is offline
Old 05-25-2009 | 06:06 PM
Are you sure you installed the impeller with the vanes bent back the correct way for the rotation of the pump?
picklenjim is offline
Old 05-25-2009 | 06:09 PM
you said what I was thinking!
502ss is offline
Old 05-25-2009 | 09:56 PM
I hate to tell u ,,,but it should still work ,,because they straighten them selfs out !!!
Old 05-26-2009 | 07:38 AM
ran the pump dry. I burned one up on Saturday as well. Something clogged the low water pickup on the Imco and completely destroyed the impeller.
Philm is offline
Old 05-27-2009 | 02:07 AM
That does not matter. They will right themselves within the first couple of rotations.
Griff is offline
