Anyone know about carb air bleeds? >
Old 05-28-2009 | 09:11 AM
Have you tried 88's with a late opening power valve...maybe 3.5? I am close with 88 X 84 with 3.5 PV's front and back. Still polishing
BenPerfected is offline
Old 05-28-2009 | 10:46 AM
I assume its square jetted now with 98s. Are you running a pv (front, rear, or both)? Have you taken a vacuum reading at cruise?
tjsmk8 is offline
Old 05-28-2009 | 12:05 PM
PatriYacht's Avatar
I have 3.5 power valves in it and square jetting. The 3.5's are so they don't open until I'm close to full throttle.
PatriYacht is offline
Old 05-29-2009 | 05:09 AM
If an overly rich cruise is your only issue, the simple solution would be to decrease the main jets to lean out cruise while increasing the pvcr's to maintain wot. If there are other tuning issues, post them as this may not be the way to go.
tjsmk8 is offline
Old 05-29-2009 | 07:40 AM
PatriYacht's Avatar
Thanks for the idea. Never thought of that.
Old 05-29-2009 | 07:46 AM
PatriYacht's Avatar
Here's a link to what I read at Speedtalk. http://speedtalk.com/forum/viewtopic...=100094#100094
Old 05-29-2009 | 10:18 AM
I have read that as well. I have learned more from Tuners posts on various websites than I ever could in a book. Unless you spend a lot of time in no wake zones, I wouldn't get into tuning the transfer slot too much. Does it idle and get on plane ok? Any stumbles or hesitation? If everything else is good, I would stick to the fuel side of it especially without a wideband.
tjsmk8 is offline
Old 05-29-2009 | 10:36 AM
We had screw in air bleeds in the race car carb. You can buy kits, pull your existing air bleeds out and thread the bore and, you can now screw and unscrew which ever size you want.
45SS is offline
Old 05-29-2009 | 12:11 PM
PatriYacht's Avatar
I have the air bleeds that you can unscrew and change. The engines idle pretty well, no fouling but a little rough. Careful adjustment of the idle are bleed screws seems to be enough. All I was going to work on was the high speed circuit.
