Toluene
Old 05-26-2009 | 09:33 PM
Default Toluene
Priced toluene at Menards 17.89/ gal, Sherman Williams 12.00/ gallon. Where can I get it cheaper? Thinking of mixing airplane fuel 101 octane, , or mixing race fuel 110 octane, any thoughts? Thanks
boatguy94 is offline
Old 05-26-2009 | 09:36 PM
careful, eats up some rubbers.
Back4More is offline
Old 05-26-2009 | 10:24 PM
JasonSmith's Avatar
Aviation fuel isn't all that great for adding octane. I'd rather run 93 from the pump than 100LL.
JasonSmith is offline
Old 05-26-2009 | 11:12 PM
Thinking of mixing 1 part 100 LL to 4 parts 93, incase 93 is'nt 93? Melted a piston last year, engine builder thought it was because of bad fuel? When they put it on the dyno, the fuel to air mixture did not need to changed so I don't think it leaned out?
Old 05-27-2009 | 12:22 AM
If you want alot look up distribution companies that sell it to sherwin Williams & menards, Ashland distribution is where I work & we ship it to both them
jmoore1225 is offline
Old 05-27-2009 | 06:34 AM
Hey Boatguy
What compresion are you running?
GoFastSonic is offline
Old 05-27-2009 | 06:51 AM
8:5:1 555 ci 871 blower, dyno 760 hp
Old 05-27-2009 | 09:17 AM
should not need more than premium fuel
I have 557's with 8:1CR/aluminum heads, 10-71's at 6 PSI with 32*all in at 2500 on 91 octane
Old 05-27-2009 | 09:30 AM
I was thinking 93 should be fine?
Old 05-27-2009 | 09:33 AM
Did it run out of fuel, close to empty.do you have fuel pressure alarms? 93 should be good for that combo? we made 803hp with 93 octane.
Thumper.
thumper038 is offline
