Need part numbers badly !! >
Old 06-02-2009 | 05:25 PM
Default Need part numbers badly !!
Changing motor over...both big block mercruisers. Old motor is a 1988 7.4L with the oil cooler on the lower side of block (rh lower if standing in front of it). New 502 Mag had (1990) oil cooler in back. I'm running my cooler the same way it was on the original motor. I'm looking for a part number for the water hose that goes from the thermostat housing down the front of the motor, along the lower side, and to the cooler ( I think it goes to the back of the cooler ). Then I need the hose that goes from the front of the cooler (I think) to the raw water pump. It sorta snakes around the front of the oil pan. Pleeeeeease...somebody's gotta know this set-up, and what the part numbers are. Thanks guys.
tinman565 is offline
Old 06-02-2009 | 05:29 PM
Try this cooler # 63832T Jim @ Mr C@@L 866-726-C@@L
good luck
Old 06-02-2009 | 05:51 PM
Thanks..but I'm not looking for a new cooler. I need the hose part numbers for the original merc hoses.
Old 06-02-2009 | 05:54 PM
Go to BAM Marine website and look up the pics and part #s
Old 06-02-2009 | 07:53 PM
I'll hafta call them tomorrow...Thanks sir.
Old 06-02-2009 | 09:18 PM
Try looking at the new and old design of the thermostat housing to see if that is what you are looking for,http://www.mercruiserparts.com/selec...?doc_nbr=19013
Boat Tech is offline
