#2 Speedmasters >
#2 Speedmasters
#2 Speedmasters
Old 03-27-2002 | 11:47 AM
Sean's Avatar
Default #2 Speedmasters
Can you bolt a #2 lower on a TRS upper? I've heard that that is all the # 2 drive is anyway...How much horsepower are they rated for and can you get parts?
Sean is offline
Old 03-27-2002 | 12:20 PM
TomFTM's Avatar
Sean, yes you can bolt on #2 lower to a trs upper. #2 parts are extremely hard to find most stuff is N.L.A. . I know of someone who has a bunch of #2 stuff around (used), I will find out if he wants to sell it, if you need it.... Tom. What are you looking at ?
TomFTM is offline
Old 03-27-2002 | 12:57 PM
Mbam's Avatar
Offshoreonly Advertiser
Yes, you can bolt it right on, but they are about 1 1/2" longer than the stock TRS. They will take more power, prblay 600 or so but parts are very hard to find.
Mbam is offline
Old 03-27-2002 | 01:03 PM
Sean's Avatar
Thanks guys...I figured parts may be an issue...but then again they will start being an issue for the TRS soon also
Time to start saving those sheckles for the new ITS when Mercury decides to let us buy them seperate!
Sean is offline
Old 03-27-2002 | 02:19 PM
puder's Avatar
speel chekk this fokker!
sean DanL had a pair of SSM2 drives don;t know if he still has them.
Billy frenz had an old race boat for sale with SSM2 drive. I know they woudl sell the boat without the drives, maybe the drives coudl be purchased.
ALso eth SSM2 drive will lower your x-dim 2"
I know someone here already tried the swicth from TRS to SSM2. I think it ra eth same speed. The 2s are lower but the TRS isn't as hydrodynamic. As i recal they claimed it about evened it out....
how is the new boat?
Pardon me, while I whip this out!
puder is offline
Old 03-27-2002 | 04:06 PM
The only difference that I know of between a TRS and SSM II upper are 2 holes. They are in the back of the upper housing and I was told that they provide ventilation to the prop. Not sure it matters though.
Yes, it will bolt up but parts are very pricey. Better to go to an SSM IIIA or V. You'll have to recut the transom with either drive.
No problems up to 500hp.
Gary
Gary Anderson is offline
Andy
Velocity
20
07-18-2013 09:40 AM
barron
13
12-17-2008 07:54 PM
boatman747
5
07-12-2007 09:54 AM
boatman747
8
03-14-2006 12:55 PM
Steve_H
07-19-2005 07:52 PM
