500 EFI Running hot >
500 EFI Running hot
500 EFI Running hot
Old 06-06-2009 | 07:39 PM
Exclamation 500 EFI Running hot
I just bought this boat with about 200 hours on it. Impeller was replaced before i bought it and i just put a thermostat in. Normally runs between 150-180 but sometimes will hit 220! I am planning on replacing impeller and backflushing the lines. Any other suggestions?
WarlockCat 28 is offline
Old 06-07-2009 | 01:06 AM
Drill three or four 1/8" holes in the stat.
MacGyver is offline
Old 06-07-2009 | 02:00 AM
It should run between 160 and 180* all the time. It definately should not get to 220*. At 200* or so, the alarm should be going off. If its not, then its a bad gauge.
Griff is offline
Old 06-07-2009 | 02:44 AM
If your boat is equipped with sea strainers, have a look at them to make sure they are not clogged
bobd is offline
Old 06-07-2009 | 03:17 AM
Also look to see if the circ water pump is leaking or not, That would make it run hot. Do you think the warning horn is working? it should beep at key up to let you know it works some times.
Boat Tech is offline
Old 06-07-2009 | 07:38 AM
Angry
The alarm is def not going off. I will check to see if it beeps with the key. The boat does not have a strainer so im afraid i sucked up something.
Old 06-07-2009 | 07:44 AM
When people talk about overheating and can't find the cause, I wonder
why no one ever mentions cleaning out the oil cooler? In fact, cleaning
out the seawater section of the oil cooler is shown as a yearly maintenance item in my 575SCi owners manual (it's the same cooler that is used on the 500EFI). You have to take them off and rod out the water section. Get all
the little tiny stones and various clogs out.
Several times over the years I've sucked sufficient sand to clog them enough to have high temps. And these are stone sizes that can make it
past many sea strainers.
Pesky Varmint
Pesky Varmint is offline
Old 06-07-2009 | 07:58 AM
Wink
The oil cooler is moounted on the back of the engine right? Looks like it will be fun getting it off, having to work around the sport tubes and all
Old 06-07-2009 | 08:19 AM
Airpacker's Avatar
you can remove the end caps ( one bolt on either end ) and use compressed air to blow out any debris in the cooler.
Airpacker is offline
Old 06-07-2009 | 11:50 AM
Sweet. Thnx every1 for the help!
