Felpro Permatorque MLS Gaskets >
Old 06-09-2009 | 07:05 AM
Biggus's Avatar
I'm running the Fel Pro MLS for the last three seasons. 8 lbs boost. No issues.
Biggus is offline
Old 06-09-2009 | 07:42 AM
PatriYacht's Avatar
The engine has to come out anyway. You should put it on a dyno when it's completed and tune for correct air fuel ratio.
PatriYacht is offline
Old 06-09-2009 | 07:48 AM
ditto
kennyo is offline
....and ditto
kennyo is offline
Old 06-09-2009 | 01:32 PM
Smitty's Avatar
The gasket is not the problem. Keep looking. And get studs to hold the heads on.
Smitty is offline
Old 06-09-2009 | 06:27 PM
Dynoed at 760hp, fuel to air mixture i believe he said was 13:1? Bolts not studs, did not use new head bolts? 6.5 lbs boost, 871 bds, too much? 9 psi fuel pressure at idle, mechanical pump, did not change, weak? use 93 octane, not enough?
boatguy94 is offline
Old 06-09-2009 | 07:44 PM
If afr is 13:1 that is too lean for a blower motor. Most run in the 11.3:1 to 11.8:1 to keep from detonationing apart. You better find out for sure.
PPlay33 is offline
Old 06-10-2009 | 01:36 AM
I would say your AF needs to be under 12.0 to make the engines live long and happy.
What is the static comp ratio????? It needs to be less than about 8.75 with 6.5-7# of boost to safely run 93 octane fuel.
Griff is offline
Old 06-10-2009 | 08:47 AM
PatriYacht's Avatar
Intercooler? Fuel pressure needs to be measured at carb at wide open. 6-7lbs. wot is ok. Do some searches here on detonation and supercharged engines, lots of info available.
Old 06-12-2009 | 01:31 PM
the MLS gaskets have a very touchy torque sequence . as well as needing to be retorqued after break in . I sold and ren fel pro performance gasket for 15 years and had no problems and the MLS gaskets are top notch . I chose to run the standard marine/performance series gaskets and im seeing around 7.5 lbs of boost with no problems yet . sounds like a lean burn or possibly failure if they didn't get retorqued after running
MillershighLife is offline
