Sea strainer location >
Old 06-09-2009 | 08:31 PM
Default Sea strainer location
I am in the process of reblumbing my scarab and plan to relocate the strainers. Origionally they appeared to be mounted about 8 inches above the water line. Is this a good height or are there some guidlines regarding where they should be mounted?
502ss is offline
Old 06-09-2009 | 08:40 PM
Its always the best to be as deep as possible ,,,but u still want to keep them where u can easily reach them also !!!
DareDevil is offline
Old 06-09-2009 | 08:59 PM
fireboatpilot's Avatar
RIPSTA Racing Team
Hey 502ss I have a hugh strainer that I ran in my Scarab. Polished aluminum with a blue top. I ran both engines off of it with no problems even when catching some air time. It's 6" round ans 18" tall with 2- 1 1/2" intakes, 2-1" outlets for relief valve and flush, and 2- 1 1/2" outlets for engines. Fittings included. This thing costs close to 2K new. I'll take $600 plus shipping. I had it mounted on the keel and sat it right on the bottom of the boat. Can't get much lower than that and it's tall enough to still be above the water line.
I also agree with DD! he's always full of.........Good info(LOL)! Hey Scott!
Attached Thumbnails Sea strainer location-ebay-131.jpg   Sea strainer location-ebay-133.jpg
fireboatpilot is offline
Old 06-09-2009 | 09:34 PM
In my 30' Scarab we mounted the sea strainers on the center stringer about 1-2" above the water line and about 6-8" in front of the bulk head. There aren't many choices and up on the firewall is not convenient.
BenPerfected is offline
Old 06-09-2009 | 09:38 PM
Hey ,,how are u and i know exactly what u ment with ........ LOL
Old 06-10-2009 | 04:10 PM
That's a nice strainer, I would consider if I didn't just got done refurbishing mine!
502ss is offline
Old 06-10-2009 | 04:18 PM
Thanks everyone for your replies. It sounds like some mount their strainers above the water line and some below the water line. Are there pros or cons for the height?
502ss is offline
Old 06-10-2009 | 04:56 PM
RIPSTA Racing Team
Hey no problem, I just thought I would make the offer. It's just taking up space till I find another use for it. Personally I would try to keep them as low as possible but keep the top of it a few inches above the water line in case you need to remove the top while in the water. I know it's common sense but figured I would mention it anyway. Your project looks great BTW. Good Luck!
Old 06-10-2009 | 05:18 PM
Thanks man!
502ss is offline
Old 07-02-2009 | 10:36 PM
mine are below the water line, i have 1/4 turn ball valves before the strainers, almost right after the transom to shut water off to un clog the strainers or in case a hose breaks.
showtime83 is offline
