350/330hp set timing without light >
Old 06-26-2009 | 10:42 PM
Default 350/330hp set timing without light
Any old timers have a trick at setting ignition timing "by ear"without a timing light? Here's where I'm at:
Boat has MSD 6M-2 Marine ignition
*new msd Dist cap on a msd 8560 Pro Billet Marine Dist.
*new magnetic pick up
*new rotor
*new wires
*new plugs
Started engine in driveway, nice idle-sounds good.
I'll test on water Sunday. Just want to play with timing a bit.
Tom
madorno1 is offline
Old 06-26-2009 | 10:46 PM
Audiofn's Avatar
Charter Member #232
rent a light from the local shop.
Put your best foot forward!
Audiofn is offline
Old 06-27-2009 | 01:43 AM
X100 That will be a lot cheaper then a new engine Or a rebuild.
Boat Tech is offline
Old 06-27-2009 | 07:42 AM
AND DO NOT USE A DIGITAL TIMING LIGHT ON MSD !!!!!!!
Get the cheapest one u can find !!!!!!!!!!!!!!!!!!!!!!!!
Sirious,,,it sometimes advances the timing by 18* with a digital light. ( BY ITSELF ) thenu end up leaning it out and burning a piston !!!!
If u don't believe me ,,,call MSD they tell u the same thing.
DareDevil is offline
Old 06-27-2009 | 09:07 AM
c_deezy's Avatar
For all the money in your parts you listed, I would think you could shell out $20 at Auto Zone for a cheap timing light.
c_deezy is offline
