SYNC Gauge How do they work?? >
Old 06-30-2009 | 12:34 PM
Default SYNC Gauge How do they work??
Ok you read the title, How do they work.
I would think when I have both engines running the exact (or Close) RPM the needle would be in the middle.
I always try to run them at the same RPM while crusing and just notice the gauge is no where close to the middle.
1BIGJIM is offline
Old 06-30-2009 | 01:33 PM
i have also wondered. good question!
Perlmudder is offline
Old 07-01-2009 | 06:26 AM
Anyone? I am guessing off the tach?
Come on there are plenty of people smarter than me out there
1BIGJIM is offline
Old 07-01-2009 | 07:11 AM
troc's Avatar
i believe the impulse off the neg coil lead fires a coil inside the scope[ same as a tach} but in a sync. scope there is a coil for each engine. when the potential across each field is 0 the needle should be mid scale[needle straight up] as on engine spins faster/slower the field becomes stronger/weaker and one coil overpowers the otherand drives the indicating needle accordingly.
troc is offline
Old 07-01-2009 | 07:52 AM
Audiofn's Avatar
Charter Member #232
You know you are synced when your motors make kind of an occilation sound. You could have a bad tach or a bad sync guage if they seem to be off.
Put your best foot forward!
Audiofn is offline
