Replace Intake Manifold with boat in water >
Old 07-01-2009 | 03:39 PM
Default Replace Intake Manifold with boat in water
Has anyone replaced their intake manifolds with the boat in the water? I would like to replace my intake manifolds in my boat (twin 454s), and would like to know if there are any issues with replacing them while the boat is in the water. I have a 30' Cruisers Inc Rogue, and we sleep on the boat on the weekends, and also use it. I do not drive the tow vehicle to the boat every weekend, so pulling the boat out of the water would be a problem. Also, the wife wouldn't like the idea of pulling the boat out and then re-launching just to replace the intakes.
If this is better done on the trailer, then I will change them after boating season here in Michigan (Sept./Oct. time frame).
Any help would be appreciated.
Thanks,
Bill
wfyehl is offline
Old 07-01-2009 | 03:45 PM
Thanks,
Bill[/QUOTE]
As long as there is enough room to get the distributers out of the engine, and you dont mind draining the water in the engines into your bilge....it sounds like something i would do.
Scarab Billy is offline
Old 07-01-2009 | 04:06 PM
That's what I thought. The only other question is: Since I have alpha drives, do I need to disconnect the water intake hose going to the re-circ pump on the engine and plug it to prevent water from re-filling my blocks? I don't think I have to, but I don't want water to infiltrate into my oil.
Bill
wfyehl is offline
Old 07-02-2009 | 07:23 AM
yeap, did my gibson, no problem....Rob
ezstriper is offline
Old 07-02-2009 | 08:01 AM
c_deezy's Avatar
Bill
Not unless your engines are way below your water line.
c_deezy is offline
