thermostst
Old 03-30-2002 | 07:11 PM
MotoFountain 127
Default thermostst
anyone know where i can get a new marine '120'
thermostat for a 502 efi
Old 03-30-2002 | 10:12 PM
Tinkerer's Avatar
Exclamation
Why would you want to run a 120 degree thermostat
Tinkerer is offline
Old 03-31-2002 | 11:47 AM
MotoFountain 127
it's part of a set up that Dustin Whipple
hooked me up with the stat got trashed and
i need a replacement i'd like to get it localy LI NY
Old 03-31-2002 | 12:29 PM
MotoFountain 127
Old 03-31-2002 | 02:18 PM
I'm pretty sure mx's response was supposed to be for the bilge pump thread. It definately makes SOME sense there.
Griff is offline
Old 03-31-2002 | 04:13 PM
Tinkerer's Avatar
Cool
Ok thats why you want the cold engine -because it's supercharged. Should have figured that out. Nat. asp. you want to run 160 deg.
Tinkerer is offline
Old 04-01-2002 | 10:56 AM
blown formula's Avatar
A 140 degree is available from West Marine. That is the lowest I have ever found. Not even Summit has a 140 degree 'stat.
blown formula is offline
