377 scorpion borken crank
The 377 Scorpion is a fantastic motor with expensive parts. The crank is a Lunati piece. Not sure what caused the failure but I'd guess there might be a vibration issue. How's the prop look?
I broke a crank once. It was when my 454 had cast internals. I had made a few mods and made about 400 HP, I thought is was too much HP for the cast crank. I think it was more likely a oiling issue. I am not sure if that relates to your buddies case. Merc Racing should have the oppropriate oiling system from the factory. That engine comes with all forged internals, should be very reliable.
The 6" overfull was after it shut down i think he will find it broke the block and water poured in at the time it broke, did not get milky because the motor was not running and never mixed with the oil. no blower just stock motors, ill keep u posted when it gets tore down.
thanks guys
thanks guys
