lifters for hp 500 >
lifters for hp 500
lifters for hp 500
Old 07-09-2009 | 05:50 PM
Default lifters for hp 500
lost a lifter on 1 motor today does anyone have one they want to sell. dont want to buy a whole set. motors are comming out this year for rebuild just trying to make it threw this season. they are the stock crane for gen 6 block carb motors thanks brian
brians fever is offline
Old 07-09-2009 | 07:21 PM
Brian,
You should be able to get a single Crane (if there are any left anywhere) or a Morel one for sure. What actually went bad on the lifter ? If the wheel or bearing came apart I would make sure and examine the cam very carefully.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 07-09-2009 | 07:36 PM
yes the shaft for the wheel went didnt loose any parts but put a very light score on the cam lobe. like i said am rebuilding them in another month or so just need a little more time. thanks
Old 07-09-2009 | 09:25 PM
upstate31sonic's Avatar
I have a set of used ones...If you are interested...Do not want to bust up the set..
upstate31sonic is offline
Old 07-09-2009 | 10:46 PM
I'm with Bill on this one. I don't know that I would simply put a new lifter in it and go... If the cam is slightly scored, it could cause more trouble and possibly cause other parts to fail.
Trust me, I know it sucks.... I lost a motor Memorial Day weekend and I have been stuck this summer building the motors again.
I hope it all works out for you.
niceguy is offline
Old 07-10-2009 | 12:13 AM
axapowell's Avatar
Where To
Upstate, are they the ones I saw? If so they looked like brand new. I get you on not wanting to bust up a set...
Good luck finding 1 Crane lifter on a shelf. After they went out, everyone pulled EVERYTHING. You may want to try a GM dealer for one. Didn't the ZZ502 use the same lifters? A used set for a few hundred dollars might get you thru till the rebuild.
Dave
axapowell is offline
Old 07-10-2009 | 05:56 AM
I have a low hour used set - of lifters & rockers - best part is the price - free
James is offline
Old 07-10-2009 | 06:34 AM
didn't the gen Vl's hp 500's use gm lifters ?
ezstriper is offline
Old 07-10-2009 | 07:22 AM
Ihave a used set you can have , mine are not the tie bar type they are the lifters with the dog bone.
rssteiny is offline
Old 07-10-2009 | 08:24 AM
You had better look at the rest of them.
And, check the inner valve springs to see
if they're broken.
JaayTeee is offline
