engine temp. >
engine temp.
engine temp.
Old 07-13-2009 | 01:16 PM
engine temp.
I have a 2005 lightning w 2 -525 EFI why is there a 15 degree water temp and 10 degree water pressure difference betreen the two.
elmoooo is offline
Old 07-13-2009 | 01:33 PM
Sounds like one of your raw water pump empellers is going bad and needs to be changed the one with the higher temp. seems like it needs to be changed from my experince that is the reason for the different temps
310DETAILNOW.COM is offline
Old 07-13-2009 | 01:41 PM
I changed the pump
elmoooo is offline
Old 07-13-2009 | 08:36 PM
Originally Posted by elmoooo
I changed the pump
...and the difference was still there I assume. Was the impeller in one piece???
Screamineagle is offline
