Leaking Bravo Alert.... >
Old 07-17-2009 | 12:39 PM
Default Leaking Bravo Alert....
I'm doing this with the search fuction in mind. No matter where you think your Bravo leaks, CHECK YOUR FILL/CHECK MAGNETIC PLUG ON THE STARBOARD SIDE. After chasing various leak areas, the O-ring on this plug has made me look like an incompetent dope. And I'm not the only one! After searching the archives for Bravo leaks, I saw pictures and other situations EXACATLY like mine. Depending on the different positions your drive is in, this leaking drive fluid will follow seam and various crevices and appear to be obvious seal leaks between the different housings. Here I was changing out seals and O-rings when I shoud have checked the obvious first. Take Care , Dave
liquidlounge is offline
