-   -   496 stroke build question (accesories) (https://www.offshoreonly.com/forums/general-q/213241-496-stroke-build-question-accesories.html)
24sleekcraft 07-19-2009 12:53 PM
Hi hope you can help. I had a marine 496 stroker built for my boat but all i have with the motor is block,heads ,intake and carb. I need everything else all pullies and accesories. I have a 1996 454 330hp motor i would sell to help pay for everything
anyone know where i can get this stuff or is there a kit i can buy. thanks.
jeffswav 07-20-2009 08:17 AM
The aftermarket has everything you will need. Check companies like, CP performance, EMI, Dana ect... There are a lot of guys here that can help you also. Be sure you get a good oil cooler.
TC 07-20-2009 12:06 PM
jeffswav is right! After my 496 build I found quickly that my factory 454 mag oil/power steering combo cooler was to small. I chose a thermostatically controlled combo cooler from CP. The unit is fairly expensive but it does exactly what it is supposed to do and is a quality piece.
