-   -   Engine Flush Systems (https://www.offshoreonly.com/forums/general-q/213584-engine-flush-systems.html)
RippersVF2 07-24-2009 09:07 AM
Any one out there use one? Saw a couple online like superflush. Do these really work like they say they do? Picking up a 1990 Wellcraft Nova ST that has been in mostly fresh water, but now it will see mostly salt. Any input would be great!
Rocko C 07-24-2009 12:50 PM
4 Attachment(s)
I've been using the Perko kit for the past few years along with the salt away mixer and solution. Very thorough but a P.I.T.A. when you just want to kill the engine at the end of a long day and go home or just chill. I installed the Volvo-Penta QL Neutra Salt system last Saturday and, man, is it easy to use ! No raising the hatch or hooking anything up. When you get back to the slip and are done for the day, flip a switch and let the Neutra Salt solution desalinate the salt water for 45 seconds (I do it for a minute), then kill the motor and flip the switch off. You're done. Couldn't be easier. My $.02, good luck !
Rock
RippersVF2 07-24-2009 08:35 PM
Thanks for these options. It looks like with the superflush system you can flush while the engines are off, which is pretty cool, if it actually works.
Phazar454Mag 07-25-2009 01:23 AM
I am using SuperFlush and I am very happy with the ease of use.
I have used it for 3 years now, but haven't disassembled anything yet to see how effective it helps against corrosion. I am planning to remove the exhaust elbows in a couple of years and then I will find out.
Rocko C 07-25-2009 08:31 AM
I was seriously considering the Superflush system myself but due to the higher price and more complicated install, I went with the Volvo system. Is the Superflush system better ? Maybe but, to me, it's not a few hundred dollars and a few more hours of install time better. I bought the Volvo system on Boatfix.com for $160 and installed it in under an hour. Either way, any flushing is better than none at all.
Rock
jezzb 04-06-2010 02:17 PM
I bought Superflush for my Merc 7.4 MPI and it has been working perfectly. I saw someone on Ebay selling it.
