trim sender limit switch >
Old 07-31-2009 | 01:59 PM
Smitty's Avatar
Me too !!!! Sorry I didn't see the parts at the bottom with no call out numbers.
Smitty is offline
Old 08-16-2009 | 11:30 AM
hpy540's Avatar
Default Thanx Boat teck
Originally Posted by boat teck
Yes you can get the round white disk by it self from merc, They call it a rotor, The merc parts guy at the dealer will find the part number in the parts book they have with photos of it in the book. Sorry I do not remember the part number off the top of my head. Keep in mind the little metel contacks at the end of each wire will need to be cleaned up Varry carefully if they look bad, And a lot of times water will get inside under the cap's "o" ring, So some times silcone will help that. This rotor is for the right side and, It is for the trim gauge only not the trim hight. I looked it up in that web site givin and thay had the part number. 805134A4.http://www.mercruiserparts.com/Show_...Steering+Lever. Look at the part numbers at the varry bottom they even have a photo, so you can make sure you are getting the right part.
Oxy moron..... Performance Boating on a budget.... LOL
Well i will see what i can do. I think i may have another issue. I did check and see that the contacts are good. As the last ones were corroded and bent. I had some sender out of a friends boat, [I] robbed the disc and the tabs out of A Alpha 2 senders that i dont know why I kept them. I put this in there and it seemed to work fine and then in the middle of the day yesterday i had no trim down. !!!!!?????? I was getting a loud clicking on tthe down and the trim up still worked. but went all the way up. Almost hyper extending the joint. Got it to trim down some to get off the sand bar, then a friend pushed us out as i was a little frustrate and we then plugged up oil cooler with sand and got the motor Hott. (I should Have told him Wait deep, not just to the bottom of your SACK!) Not bad though. But now tear it all apart.
Any way back to the 2nd part of the next question. WOuld Wear( Absence of metal) on the Rotor disc cause the trim pump to not function down( I am not familiar with the schematics of Mercs trim/limit)? Or do i have a bad solenoid. The boat is beginning to show its age on some of these parts and i would really like to just replace the Whole trim pump ass but It aint gonna happen this year. I will be done boating if that happens.
Thanx Again to all helpin me on this.
Regards
hpy540 is offline
Old 08-16-2009 | 11:55 AM
Wobble's Avatar
SORE MEMBER
Regards
down function is not affected by limit switch
Wobble is offline
Old 08-16-2009 | 12:26 PM
hpy540's Avatar
Bad solenoid then?
hpy540 is offline
