Water Crossovers >
Water Crossovers
Water Crossovers
Old 07-30-2009 | 11:03 AM
Default Water Crossovers
Can somebody please explain the pros and cons of running water crossovers
Pokher Ace is offline
Old 07-30-2009 | 12:23 PM
Do a quick search and you'll find a million threads on this. Basically, 50% like the circ pumps and 50% prefer the crossovers. Some say circ pumps eliminate hotspots. Other say drill the t-stat with small holes and that fixes it on crossover apps.
niceguy is offline
Old 07-30-2009 | 05:28 PM
I use the crossover with bypass. Drill two 1/8" holes in the thermostat. Looks cool, eliminates another moving part. And it goes way faster and free's up HP. Don't get your hopes up on that last one.
jeffswav is offline
Old 07-30-2009 | 06:57 PM
Does it require a two stage sea pump?
Old 07-30-2009 | 07:03 PM
johnnyboatman's Avatar
no uses same pump
johnnyboatman is offline
Old 07-31-2009 | 01:52 AM
On a stock engine a crossover is a waste of $$$ and will more than likely create problems. They also do not work well on efi's.
Griff is offline
Old 07-31-2009 | 06:13 AM
mine was already on the boat when I got it, but with no bypass and therm. ran way to cold, changed to a bypass one and therm works great and runs consistant 150 deg. so one less part to fail and freeing up some H/P I like them...Rob
ezstriper is offline
