Do i need a fuel regulator
1 Attachment(s)
Problem is,
My fuel regulator is showing full pressure on my guage. i had a little mishap over the weekend. basically my serpentine belt decided to give way and somehow something might had hit the regulator, and now is not working. when i turn the key the pressure goes from 0 to 15psi. it is also linking gas around the set screw/allen key. hopefully i have this right, when i wind the allen key screw in am i increasing the pressure or decreasing it. i was by myself with little time to spare so i did not have time to play around with it. my engine is a carb engine and it requires a min. of 6 psi's, right now i took the fuel regulator off and i have the fuel pump out line running to the carb instead of the fuel regulator than carb. also i running the holly blue pump, is it pre set at 7psi's not sure and it runs abit warm is this normal. i also started the motor with out the fuel rugulator and it seem to run fine on the trailer.. any suggestions or info will be gladly appreaciated.. thanks Q |
| All times are GMT -5. The time now is 06:01 PM. |
