bbc question >
bbc question
bbc question
Old 08-06-2009 | 07:20 PM
Default bbc question
where is the best spot to put oil preasure switch sending unit on bbc thanks.
joepequa is offline
Old 08-06-2009 | 07:40 PM
Default bbc
bbc
joepequa is offline
Old 08-07-2009 | 12:09 AM
Plug in the block right by the oil filter.
picklenjim is offline
Old 08-07-2009 | 11:40 AM
great thanks
joepequa is offline
Old 08-09-2009 | 08:55 AM
How about oil temp and low preasure alarm.
joepequa is offline
Old 08-09-2009 | 11:03 AM
bbc
joepequa is offline
Old 08-09-2009 | 11:18 AM
c_deezy's Avatar
Same place usually, what block is it? BBC is too generic, you need to be specific. FWIW on the HP500 block they are all right next to each other on the port side of the block, in front of the oil filter adapter along the pan. I forget where they are on my 454...
c_deezy is offline
Old 08-09-2009 | 11:23 AM
Default dart block
i have a dart block i am looking for a spot for the oil preasure switch,low preasure alarm and oil temp any good spots thanks joe
joepequa is offline
Old 08-09-2009 | 11:56 AM
If possible, put the oil temp sender in the oil filter housing. There really isn't a good place in the block to put the oil temp sender where it is in the flow of oil. You must have the temp sender in the flow of oil to get an accurate reading. You do not want it in a dead end cavity with stagnate oil. The pressure sender can really go anywhere. Put the oil alarm sender up high on the rear of the block just above the bell housing. Hope this helps, Eddie.
Young Performance is offline
Old 08-09-2009 | 01:53 PM
great thanks for the info
joepequa is offline
