Can I put my water pressure gauge line here >
Old 08-06-2009 | 09:44 PM
Velocity Vector's Avatar
Crazy Energy
Default Can I put my water pressure gauge line here
My water pressure line is on the block and keeps getting stopped up with trash, can I get a reading here on the water lines going to the headers...
Velocity Vector is offline
Old 08-06-2009 | 09:53 PM
mopower's Avatar
Toxic FORMULA
May be lower there
mopower is offline
Old 08-06-2009 | 09:56 PM
Crazy Energy
There is another plug on the oposite side of the temp sender would it be better there.
Old 08-06-2009 | 10:04 PM
Yes, that is an acceptable place to put the water temp or pressure sender. If you are going to run a small water line (mechanical gauge vs. electrical) to the dash, it might look nicer to run the line from the rear of the intake manifold (brass plug in your picture). Another option is to switch your water temp gauge to the front fitting. Lot's of choices on the Brodix manifold.
BenPerfected is offline
Old 08-06-2009 | 10:10 PM
Crazy Energy
That would look better running it under the manifold, there is a bigger plug in the right rear but I couldn't budge it.
Old 08-06-2009 | 10:20 PM
If you use a 6 pt socket with a 6-12" extension and a breaker bar that brass fitting will come out
Old 08-06-2009 | 10:30 PM
Crazy Energy
That 3/8's ratchet I had on it fell short.
