Stumped
Old 08-08-2009 | 11:50 AM
Default Stumped
My friend has a 1968 boat, It has a 283 chevy engine with a Quadrajet carb on it. The problem is we brought a rebuilt carb put it on and the engine will idle for a minute then die. and if you try to give it any gas it just dies. The points,timing,wires, plugs, and fuel pump are all new and set to specs. so thought it was the new carb was bad, so I then put the old one on to try it and it did the same thing. ANY thoughts would be great I'm stumped. there is also no egr, or any vaccum to the carb. Real basic system points,mechanical timing advance, remote choke, etc.
Scooter is offline
Old 08-09-2009 | 09:08 AM
hoozeyurdaddy's Avatar
hook up a remote fuel sys. with a primer bulb and see if it is a fuel starvation problem, by-pass the fuel pump and go straight to the carb, you will have to keep pumping the bulb, but it will tell you if there is a problem down stream.
hoozeyurdaddy is offline
Old 08-10-2009 | 04:58 PM
Thanks for the input, will give it a shot.
Scooter is offline
Old 08-10-2009 | 09:45 PM
PAST DUE's Avatar
make sure you installed the correct gasket under the carb
PAST DUE is offline
Old 08-10-2009 | 10:39 PM
How soon can you re-start?
Spray carb cleaner or starter fluid as you open throttle might be a little more controllable...but it's a good idea for some type of fuel blockage.
Sounds like fuel problem. Some causes are float level too low/stuck or float valve stuck.
Before you go inside, pull the flame arrestor and look at the carb as the throttle is given. Too much gas is a possibility(watch choke plate)...or maybe somehow secondaries opening too soon. I know it don't sound right. Especially with two different carbs.
jtybt is offline
Old 08-11-2009 | 05:05 PM
It's getting fuel for sure., but when you spray carb cleaner in, it kinda wants to run alittle bit better, for a very short time. it's the right gasket. not new at mechanics just this one has me quessing hard.
Scooter is offline
