fuel pump leak >
fuel pump leak
fuel pump leak
Old 08-15-2009 | 10:18 AM
1 MAIDEN AMERICA's Avatar
Default fuel pump leak
I have the mechanical fuel pump mounted on the raw water pump driven by a belt. Gen V? Fuel gets into that oil reservoir. On my old boat I changed both pumps and a month later fuel was in the reservoir again. The pumps always worked so I left it and just changed the oil regularly. Does anyone make a pump that wont leak that's a direct fit to a 575SCi? If so what's the warranty? I've seen the $500 mech pumps and will buy them if they have a good warranty. Good should be about 10 years given nothing but fuel gets into them.
Rob
1 MAIDEN AMERICA is offline
Old 08-16-2009 | 06:32 AM
MER Performance's Avatar
He you go! Call CV Products, Thomasville NC, ask for Dan Kent, Tell him you want the Merc Marine Billet fuel pump. $430.00 I think for over the counter customers. You'll never have to replace it, check valves can be replaced & diapham.I believe that pump come with a 5-7 psi spring in it. BEST ONE OUT THERE BY FAR! Mark
MER Performance is offline
