-   -   "HELP" ASAP (twin eng. center line/headers) (https://www.offshoreonly.com/forums/general-q/215110-help-asap-twin-eng-center-line-headers.html)
getrdunn 08-20-2009 02:22 PM
i'll keep you posted. any good number to get a hold of cmi to confirm. seems like i was on there site the other day and don't recall seeing a tech number or any number at that.
thanks for your help.
john
Panther 08-20-2009 04:26 PM
I had e-tops on mine, 32 1/2" centers.... you had to jockey them into position but they worked and were very tight...
I'm running Stainless Marine Gen II's with custom 4 1/2" tails now. The Gen III's unfortunately wouldn't fit, even after the flanges being machined.
Hardin will also build you a set to fit.
getrdunn 08-20-2009 04:59 PM
thanks for your response. seems as though they might be a tight fit but should work. i guess i'll find out soon. after reading young perf. thread i am a little leary about the collecter area. was the collecter area a problem for you? looks like if i'm lucky i'll have maybe at most 3/16 to 1/4 inch max between the tuubes. know i am concerned in regards to the flange though. any info. on this would be great.
john
Panther 08-20-2009 07:44 PM
I'm probably not the right person to ask my opinion on stainless steel headers, my headers had to be fixed every other season.
I highly recommend installing a drain tube so when you shut down the engines it automacitally drains them down. All it takes is a little 1/8" hose.
