Siphoning Gas
Post #6.
the 10% ethanol with absorb water and never settle out.
QUOTE=blue thunder;2937375]i disagree that this would not be a quite satisfactory approach ethanol or not. Water is water and it will go to the bottom even if there is 90% fuel, 10% ethanol vs 100% fuel. What is your proposal for getting rid of the fuel then, dump it out behind the garage
?[/QUOTE]
?[/QUOTE]
Post #6.
?ethanol / water mix will phase separate as more water is added. the water rich phase on the bottom won't burn, but the phase on the top which will have less ethanol than the original mixture as well as less water will be fine to burn in normal stuff - especially if diluted with more fuel or if dry alcohol is added to further increase the water carrying capability of the fuel. not much different than putting drygas in your tank to run water through that builds up from condensation.
burn the stuff onthe top, let the bottom evaporate in a can or something and throw the remaining sludge away. no worries... if you;re worried about what to do with the very little bit left after the water and ethanol evaporate from the bottom 9mailny water) layer, then mix it with motor oil you talk to the recycle station. it'll get blended into fuel oil and burned in a powerplant to recoup the btus from the oil...
