ECM programming help >
Old 08-28-2009 | 03:51 PM
Default ECM programming help
Anyone know of some ECM re-programming companies.. Would like to bump things up a little and bump the rev limiter up about 400rpms too.
silent lucidity is offline
Old 08-28-2009 | 06:45 PM
what ecm ? i've had arizona speed and marine make some changes for me before with good success
Unlimited jd is offline
Old 08-28-2009 | 07:54 PM
http://mefituning.com/
dogturd21 is offline
Old 08-30-2009 | 08:54 AM
http://www.mefiburn.com
talk to Bob, He has done several ECM's for me and all have worked without any issue.
motorz is offline
Old 09-01-2009 | 02:39 PM
x2 on Bob @ OBD Diagnostics (MefiBurn). We use the MefiBurn to load our tunes for the 383 we built and the actual TunerPro software is great. The Customer Service is top notch also.
I've spoken with ASM and the interaction was bad...not to mention the bad repoir they have around the forums.
rangoneer is offline
Old 09-01-2009 | 04:20 PM
OBD's stuff looks great...I am looking to purchase a scan system for a PCM-555 (2008 496), is Rhinda my only options, or are there others...cause they are way expensive compared to OBD....put it seems OBD does not carry the PCM stuff.
Thanks in advance
instigator31 is offline
Old 09-03-2009 | 09:58 PM
Mark Boos, Precision Marine in Kenner LA for reprogramming: 504-469-7463
ctuck0659 is offline
Old 09-03-2009 | 10:27 PM
littledcsrodshop's Avatar
I realize there have been several companies mentioned here but if you are still looking give Eddie Young a shout 615-216-7449
[email protected]
littledcsrodshop is offline
Old 09-05-2009 | 04:08 AM
Thanks all. Will be making some calls.
Old 09-05-2009 | 05:26 AM
Where are you located?
trawfish is offline
