worn distributor gear >
Old 09-03-2009 | 01:26 AM
The gear material on the cam gear determines the gear material needed for the distributor gear. Crane cams used a pressed on steel gear and you could run the stock distributor gears.
Griff is offline
Old 09-03-2009 | 06:58 AM
time to pull the engine down, the cam you have takes a std iron gear, so something is wrong, but all that metal is now embedded in the bearings thru-out the engine, keep running it...well the pin has been removed....Rob
ezstriper is offline
Old 09-03-2009 | 08:41 AM
Another cause could also be a leaky intake gasket....I had a gear wear out becuase of water dripping down the dist. hole under the intake in the valley.
Back4More is offline
Old 09-05-2009 | 05:17 PM
There's a website called Pace Performance Parts- they have the hardened gear to use with a billet cam for $40.00. The Merc Dist. is a .491" diameter shaft.
ctuck0659 is offline
Old 07-20-2010 | 01:04 PM
I realized it never had a cam retainer installed when it was switched over to the roller cam so cam walk is what was tearing up the gear. I put a bronze gear in & now wonder if thats ok or if I should switch it back out for a composite or another harden gear?
Itsallgood995 is offline
Old 07-20-2010 | 03:28 PM
I used to run bronze gears on my drag motors before the gear improvements avail. now. the problem is they wear rather fast and leave trace metal in the oil. you will see a gold sheen when changing oil always been scary to me!
doggiedave is offline
Old 07-21-2010 | 01:38 AM
The bronze gear will wear out pretty fast on a pressed on steel cam gear. I would change it.
Griff is offline
Old 07-21-2010 | 06:49 AM
This is what you need
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
1BIGJIM is offline
