crossovers / help >
crossovers / help
crossovers / help
Old 09-03-2009 | 02:43 PM
Default crossovers / help
Are crossovers worth it on twin 454mag mpi with Gill exhausts and reprogramed ecu. (soon head work) Or will I have overheating issues..
Been known to vapor lock from time to time.
Boats a 312 Fastech
silent lucidity is offline
Old 09-03-2009 | 03:06 PM
bcfountain's Avatar
Registered User
Default crossovers
i do not think you will have over heating problems,just the opposite.getting the motor to run temp.i have had two of these set ups on two diffrent motors.you want to have the engine temp around 140-165,depending on whitch type motor you have.benifets,you gane 5-10 hp.a little more room on the front of the motor,and a cleaner looking engine,simpler too.hope this helps
bcfountain is offline
Old 09-03-2009 | 05:32 PM
If you have a cerpentine belt it is a more expensive. I think it was CP performance that had one for the single belts system. If you have V belts it is much easier.
jeffswav is offline
Old 09-04-2009 | 06:26 AM
they work fine, just make sure you get one with a bypass and run the thermostat, or will run way to cold...Rob
ezstriper is offline
Old 09-04-2009 | 04:31 PM
CPPerformance's Avatar
Thumbs up
Let us know if we can help, we sell lots of these kits with great results. http://www.cpperformance.com/detail.aspx?ID=7588 Dont forget to mention OSO for a possible member discount.
Brad
CPPerformance is offline
Old 09-05-2009 | 03:49 AM
Default thanks
thanks all for the info,, looks like I'll be spending mo money.. Wife loves when I hit this site,,ha
