Drive Indicator not working >
Old 09-05-2009 | 09:14 PM
Default Drive Indicator not working
Need help with my Drive Indicator on my Dash,
Ever since i installed the new engine The Drive Indicator on the Dash is not working, i checked the wires behind the gauges and everything looked fine. The drive works, but i would like to know where my drive is when i driving, what should i be looking for , and where should i look..
thanks Q
qaberdeen is offline
Old 09-06-2009 | 02:34 PM
H2Xmark's Avatar
make sure you have all your grounds hooked up after the motor install.
H2Xmark is offline
Old 09-06-2009 | 11:21 PM
CB-BLR's Avatar
Chris
x2
CB-BLR is offline
Old 06-14-2010 | 08:07 AM
fellas,
i think i found the problem.. i found two wires coming out of the transome plate that r not connected..they look both to be black, with each having two leads on them..but i'm not sure where they plug into.. i went from an efi to a carb motor, so i'm not sure why the engine installer did not connect them..maybe one goes to the guage and the other ?..i will take some pisc tomorrow and post them..
thanks Q
If u look at this pic, right behind the flame arrestor, on the transome with the black strap around it. its the trim pump canister i think, is something suppose to be pluged into that because it has to wires hanging that were connected to the efi engine, but now it's not..
