Water Pressure Too High!!! >
Old 09-09-2009 | 01:38 PM
rslick's Avatar
Originally Posted by Griff
Where were the 4 hoses going before you switched to the 2 hose housing???? Were they T'd together and going only to the manifold or were they run just like Gils with one to each manifold and one to each riser???
On the 4 hose t-stat I t'd the two on each side into one and it ran it to the bottom of the manifold. Eickert manifolds only use one line in.
rslick is offline
Old 09-09-2009 | 08:36 PM
I believe that is the issue. There is simply too much water going in and it can't get out fast enough.
Griff is offline
Old 09-09-2009 | 08:43 PM
CB-BLR's Avatar
Chris
I agree. I would dump a couple of lines off the back of the intake manifold. It will increase exit water flow, and help with more uniform cooling.
Chris
CB-BLR is offline
Old 09-09-2009 | 09:16 PM
Default mrfixxall
Originally Posted by rslick
Yes heads too, AFR. I figured they would have nothing to do with the water flow.
restrictive hole's in the head gaskets,,want your old heads back? ill trade you for the afr's
FIXX is offline
Old 09-09-2009 | 10:35 PM
i know you some what joking however you can get gaskets that need to be modified to suit your application... there is so many gaskets and only so many interchange however some can with mods to the water jackets.
i would think the temps would be show this though.
getrdunn is offline
Old 09-09-2009 | 11:24 PM
have you checked your thermostat to see if it is opening all the way and is there a bypass from where the water enters the block to down stream of the thermostat. If there is any obstruction the water pressure will be excessive.
GERRYM454 is offline
Old 09-13-2009 | 06:32 PM
rslick's Avatar
Checked t-stat this weekend and installed another for the heck of it. No change in pressure. I was kind of thinking maybe head gaskets? I used Felpro marine. Has anyone had issues with these?
Where in the rear of the intake would you bleed water from? I did not see any areas that would accept a fitting?
rslick is offline
