Help with plumbing an electric fuel pump. >
Old 09-11-2009 | 12:48 PM
Default Help with plumbing an electric fuel pump.
I'm looking at swapping from a manual fuel pump to an electric Holley. My tank does not have an extra tap for a return. Can I tie into the suction of the pump?
powerquest rick is offline
Old 09-11-2009 | 12:50 PM
most holley pumps dont require a return line,
are you using a dead head regulator ?
cbellamore is offline
Old 09-11-2009 | 12:58 PM
Default mrfixxall
mount it as close th the tank as possible and low in the hull,also you need to suck the fuel through a filter..theirs several ways to hook it up through a regulator.call me if you would like i have several ways of doing it..
FIXX is offline
Old 09-11-2009 | 04:17 PM
I dont know what kinda power your making...but a Holley Black (140 gph) should be enough for you...and they dont need a return line..just buy the recommended regulator. Check out Summit Racing sir.
tinman565 is offline
Old 09-11-2009 | 05:30 PM
Thanks everyone.
Old 09-11-2009 | 06:48 PM
http://teaguecustommarine.com//store...l_manifold.pdf
You can find this and several other drawings at teaguecustommarine.com under the Tech Tips section.
picklenjim is offline
