Should I weld block >
Should I weld block
Should I weld block
Old 09-18-2009 | 09:42 AM
Registered User
Default Should I weld block
I burnt the the block between 2 cylinders on a blower motor has anyone had bad results from welding the block.
scarab600 is offline
Old 09-18-2009 | 09:57 AM
Default mrfixxall
Call bill at ateco engines,he advertises here and has done many repairs on decks of 502's..if you dont have head studs now is a good time to invest in some..
FIXX is offline
Old 09-18-2009 | 09:59 AM
what kind of block
if its stock it might not be worth it
you can usually find good condition used ones for a cheap price if you hunt around
cbellamore is offline
Old 09-18-2009 | 01:17 PM
Ateco's Avatar
Default Ateco
We weld alot of blocks during the boat season, runs about 250.00, also if necessary we can even sleeve the block.
Plaese call if you have any questions. Thank you.
847-623-2737
Matt
Ateco is offline
Old 09-18-2009 | 01:35 PM
Do yourself a favor & find another block and save yourself the headaches and Ass fuchin your gunna get from A
Good luck Bro
Old 09-18-2009 | 03:10 PM
Registered User
Its a 502 gen VI
Old 09-18-2009 | 03:33 PM
Strip Poker 388's Avatar
Rob
what head gasket were ta running?
Strip Poker 388 is offline
Old 09-18-2009 | 03:35 PM
Default mrfixxall
Its a 502 gen VI
Here ya go!
ill send you a pm
FIXX is offline
Old 09-18-2009 | 03:43 PM
Registered User
Fel Pro Hi performance marine
Old 09-18-2009 | 10:05 PM
Scarab28's Avatar
Had one welded once between cylinders, no issues runing turbos after.
Scarab28 is offline
