Main Caps .................help >
Old 09-22-2009 | 11:46 PM
Default Main Caps .................help
ok so i spun a main bearing on my gen V 502.... i REALLY need 2 main caps so I can try and save my block. We have tried a few and they wont work, so i need MORE main caps to try and make work to save my engine. If anyone can help it would be awesome. Just let me know how much you want for the caps? AND if the caps dont work I will ship them back at my cost. Please help. Thanks
conquest30' is offline
Old 09-23-2009 | 12:38 AM
Wink
Contact ProGram Engineering. They make replacement main cap sets for almost all big blocks.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 09-23-2009 | 12:52 AM
http://www.hawksracing.com/maincaps.htm http://www.pro-gram.com/
Here's a couple of places that make them for custom registering.
picklenjim is offline
Old 09-23-2009 | 08:26 AM
Eagle also has main caps.
niceguy is offline
Old 09-23-2009 | 12:26 PM
Is the damage to the original caps way beyond the scope of aline boring or honing I assume it is extensive. Get 5 new caps and bolts and aline hone the block to factory spec. tolerances. good luck
I'CE is offline
Old 09-23-2009 | 03:23 PM
i was hoping to find some stock orginal main caps ............. i heard if you line hone and move the crank up to much it will leak out of the rear seal?
Old 09-23-2009 | 05:21 PM
You will deffinently have to align bore this block if it has spun a main, regarless weather you use new, used, or your old caps.
RHM253 is offline
Old 09-23-2009 | 06:22 PM
GM also has new caps for a very reasonable price. They are unfinished and will require line boring. A good machine shop should be able to align bore and hone the block for you without moving the crank up more than a few thousanths. Unless of course the spun bearing did more damage than that.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 09-23-2009 | 06:45 PM
Michigan Mad Man
You need to take the block to a machine shop and have it line bored with the new caps. You will have nothing but problems if you don't.
TylerCrockett is offline
Old 09-23-2009 | 06:57 PM
jayhawk261's Avatar
The caps and block are matched by align boring. You won't find a cap that will just bolt up and fit like the others. Any new cap will have to be align bored/honed to match the block.
jayhawk261 is offline
