Opinions On Exhaust
If you are going to spend money on looks and performance why buy manifolds?
CMI E-Tops or Sport Tubes are headers with style and performance. Ask about the CMI Unitops as they are priced nearly the same as the other guy's manifolds.
i have used both stainless marine and emi,s.i just bought a set of emi,s this year.very happy and the warrenty is the same as stainless marine,but cheaper.i bought my emi,s from diamond performance.they are advertizers on here and have great prices,and great service.
Welded tube headers look the best but cost the most and have a history of developing cracks over time which results in water getting into the cylinders and then hydraulic lock engine damage if not diligently leak tested and repaired when the cracking occurs. CMI's are consistently mentioned as providing the most hp. You only get the rated hp improvement if you run them dry since wet exhaust increases back pressure.
I opted for the Dana Torque Flow exhaust manifolds which are roughly similar to the KE aluminum header dedsign approach ie extended individual internal runner length. The Dana's cost half that of CMI's and with them one does not have to worry about cracking and associated leak testing to monitor for same and repair. They do not provide quite the hp that a set of CMI's would but close enough given the other benefits.
My 0.02.
My 0.02.
Eddie marine are a very nice set up with the stainless risers and perform just as good has the rest and come with a 5 year warranty.
http://www.eddiemarine.com/techsuppo...502_5483_3.pdf
http://www.eddiemarine.com/techsuppo.../warranty1.pdf
