HELP with wiring - TB-1V >
Old 09-30-2009 | 06:03 PM
Default HELP with wiring - TB-1V
hello and thanks in advance for your help. i had a post a while back and someone helped out with a diagram for wiring however i had a difficult time making it out. it probably had the answer to my question but i couldn't read it.
i am doing a test (floor run) on my engines this weekend and have the TB-1V ignition. i am not going to have the main harness hooked up for this and just need to know what wires i will need to hook up to the COIL and BATTERY. The wires that i recall that need to be hooked up are the PURPLE and GREY from the module. the others are color coded to the distributor as well as a ground wire.
i just need to know what colors go to the positive and negetive side of the coil as well as the possitive and negetive of the battery. also i would like to use the ignition key switch as well. it seems like there is 3 post on the back of that. i could probably use a generic push type starter switch but i would rather use the extra merc key switch that i have instead.
anyone with any advice would be greatly appreciated. i thought about using a HEI dist. for simplicity for this test however i would like to make sure the ignition that i am going to use long term works OK.
Thanks again,
john
getrdunn is offline
Old 09-30-2009 | 06:25 PM
Default mrfixxall
i just need to know what colors go to the positive and negative side of the coil as well as the positive and negative of the battery. also i would like to use the ignition key switch as well. it seems like there is 3 post on the back of that. i could probably use a generic push type starter switch but i would rather use the extra merc key switch that i have instead.
Thanks again,
john
all you need to hook up is a + wire to the + side of the coil..if the module is grounded it should ground through the battery negative cable. purple goes to the + side of the coil,grey - side of the coil..hook up your battery cable to your starter,then to the battery,hook up your negative battery cable to the back of the block..on the back of your key switch it should be marked b-battery,i- for ignition,and s - for start a- is for assory.run a fused wire from your battery to b-on the switch,run a wire from the + side of the coil to the i- on the switch,run a wire from the s- on the inside pole on the starter to the s on the back of the switch..don't worry about the - side of the coil unless your hooking up a tach..
FIXX is offline
Old 09-30-2009 | 07:57 PM
hey thanks for the help. i do recall the starter switch having the terminals labled as you said however everything is up to my shop and not in front of me. with my entire set up being different than what i origially started with i just wanted a little advice, (help). my old ignition was a points dist. this will help a bunch. thanks again for taking the time to help out.
i'll post the results this weekend.
john
getrdunn is offline
Old 10-01-2009 | 11:57 AM
blue thunder's Avatar
To shut the engine off once running then just remove the 12v wire from the + side of the coil. I use an alligator clip at this point to make it easy. I use the starter switch from actron.
blue thunder is offline
