Intake Upgrade ??? >
Intake Upgrade ???
Intake Upgrade ???
Old 10-10-2009 | 06:34 PM
Craney's Avatar
Default Intake Upgrade ???
I have 468s with Weiand team G single plane intakes with Nickerson 830 carbs. Would I have better performance with dual plane intake??Also rec.heads and S-M exhaust.
Craney is offline
Old 10-10-2009 | 09:30 PM
Not enough performance change to justify the cost. I would say maybe a 10-20 lbs increase in mid-range torque and little to nothing on the top end.
BenPerfected is offline
Old 10-10-2009 | 10:09 PM
The Team G is a good manifold. For the rpm's the boat runs, a single plane is the way to go.
Darrell.
DMOORE is offline
Old 10-11-2009 | 02:51 PM
Depending on your pistons, cam etc, unless you're running like a pig down low at the moment, i'd say if it ain't broke, don't fix it.
The rect port heads need to breathe and the Team G will do that. If you're lacking low end, try an HVH SS Carb spacer, they're cheaper than a new manifold.
If it's all good now though, leave well engough alone.
Ghostrider is offline
Old 10-11-2009 | 08:05 PM
You will gain low and possibly mid but top end will suffer. You wont be happy trust me.
OutlawMan is offline
Old 10-11-2009 | 10:35 PM
the carbed hp500 uses a singel plane manifold.
mike tkach is offline
