-   -   Conversion (https://www.offshoreonly.com/forums/general-q/218799-conversion.html)
tdrags00 10-19-2009 05:08 PM
Conversion
Hey guys i have 1987 formula 223 and i am converting the outdrive from a alpha to a bravo and i was wondering if there was anything else that would have to be change to complete it
Brad Zastrow 10-19-2009 08:22 PM
I am not an expert but I think you need to drill two more holes for the mounting. And you will need to add a sea pump for sure. The Alpha has the pump in the drive the Bravo does not. I am not sure about the cables or steering.
hoozeyurdaddy 10-20-2009 09:01 AM
you should change the coupler over to the bravo coupler also, steering and cables should work fime, just make sure you route the shift properly.
fireboatpilot 10-20-2009 03:41 PM
I have HP transom assy's and Bravo 1 drives available. All used, fresh water units. Tight, low hours.Pm or email me if needed. [email protected]
