Hot Gill exhaust risers >
Old 10-22-2009 | 06:53 AM
Farquar's Avatar
Hello; I need advice on too hot Gill exhaust risers on one of my 500 HP engines. The motor runs too cool(100 degrees) while the risers are too hot. Water pressure seems to low (1 pound @ idle)and 5 pounds while running. This just started and I'm thinking I need to rebuild the impeller pump,and maybe a stuck open thermostat. Thanks for your input.
Farquar is offline
Old 10-22-2009 | 09:24 AM
Default mrfixxall
I would do both impeller and thermostat..also check the oil cooler for pieces of the impeller,even if theirs none of the blades missing on the impeller you take out..Still check it,also check the intake hose at the gimbal to drive,make sure i isn't collapsing also check the hose going from the gimbal to the sea water pump..
FIXX is offline
Old 10-22-2009 | 12:59 PM
Probably a bad/broken impeller and part of it is stuck in the T-stat.
Griff is offline
Old 10-22-2009 | 05:16 PM
MOP
Lightbulb
IMO 5psi running is low, 15psi at WOT is hwere I fell it should be.
MOP is offline
