502 Build??? Need advice!!! >
Old 11-20-2009 | 02:47 PM
Originally Posted by Advantage 27
I am going the route described by Eddie. I am turning a 509 into a 540 (melted a piston) and will be getting the Holley intake and using my MEFI4. I have to say that working with Eddie has been great and he is very meticulous about building a motor which will be rock solid. If your looking for a builder then he is the guy.
Shane
Thanks buddy. I will send you a few more pics as soon as I finish buttoning up the bottom end.
Eddie
Attached Thumbnails 502 Build??? Need advice!!!-shane-547-efi-9-.jpg   502 Build??? Need advice!!!-shane-547-efi-14-.jpg   502 Build??? Need advice!!!-shane-547-efi-12-.jpg
Young Performance is offline
Old 11-20-2009 | 06:25 PM
Default Decision Made! Unless some one can give me another provin combo?
Decision Made! Unless some one can give me another proven combo?
Building the Stock 502 Mag efi then selling it! Selling my present 454 MPI. Then building a 502ci, 850 Carb, Aluminum AFR head, high rise intake, custom cam combo that Thunderstuck is running= 600HP.
Any other proven packages they would like to put out there for consideration?? Open to IDEAS!
THanks for the advice.
powerquest208 is offline
Old 11-20-2009 | 08:07 PM
Who is building it???
Old 11-20-2009 | 10:01 PM
Default Assembly
I will have the short block assembled then assemble the rest my self. I might even assemble the short block. I will dyno & test the motor @ a shop close by. I have done small blocks but have never done a BBC. Blocks are @ the machine shop getting honed & new cam bearings. I know ur in the business. What services do you have to offer?
Old 11-21-2009 | 03:53 AM
That young link takes you to a domains for sale page..
Pismo10 is offline
Old 11-21-2009 | 09:30 AM
What pistons are those in the pictures. They look like they have a small dome.
pslonaker is offline
Old 11-21-2009 | 10:39 AM
Thanks. I need to look into what the hell is going on. My site has had that domain name for years. I will be on that today.
Those pistons do have a small (10 cc) dome. They are made by JE
Powerquest, I pretty much do it all from custom engines, drives, rigging, tuning efi and carb, etc. Give me a shout if I can help you in any way.
Eddie
Old 11-21-2009 | 12:16 PM
Havent seen the link thingy you are referring to, but to protect yourself...go to your court house and register your stuff under an assumed name. I have done all my stuff this way and have only had one issue. When I showed the people the documents that I had everything registered, the piss & moaning was over.
Would you happen to have the JE part number for those pistons and are they for a 540?
Old 11-21-2009 | 12:28 PM
The pistons are actually for a 547 ci. (4.25 stroke, 4.530 bore, 1.27 CH). The number is 212162.
Eddie
Old 01-28-2010 | 10:29 AM
Where are you getting the CAM and what is it?
Swamplizard is offline
