Upgrading to a performance cam in 454? >
Old 11-18-2009 | 10:13 AM
Default Upgrading to a performance cam in 454?
I have a 24ft Chaparral with a factory 454 which has been modified with an inner cooler, ignition and 7lb supercharger by ProCharger. I need to say I am no expert on engines, and am curious if what all goes into changing cams. Is it as easy as replacing the cam, or do I need to change out many more parts on the engine. Also anyone have any idea of cost to put in a performance cam as well as troubles I may encounter. Is a performance cam harder on the engine etc?
lilwigs is offline
Old 11-18-2009 | 03:59 PM
you will need a good blower profile cam, lifters(hyd roller the way to go) new springs, retainers, locks and pushrods. I would also repalce the timing chain set while its apart...how many hours on the engine....maybe time to freshen the rest ? Rob
ezstriper is offline
Old 11-18-2009 | 06:49 PM
I agree, valvetrain needs to be a matched set. I am not into superchargers but you may need to change the exhaust also. If you are serious call RMbuider he will set you up with a complete package.
jeffswav is offline
